Foundation Post Place Direct Int Ground - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 02:24 PM   #1
foundation post place direct int ground
it it smart to use 6x6 treated post as a foundation directly in the ground?
tom barnes is offline   Reply With Quote
Old 11-15-2011, 03:37 PM   #2
concretemasonry's Avatar
Rewards Points: 2,566
No, unless you want a temporary foundation (even if it meant for direct contact and is not "pressure treated").
If it is a foundation for structure, the cost of repair later is far greater than doing it right in the first place. Just use a concrete post with a galvanized bolting plate the keeps the wood slightly above the concrete (1/2").
Dick
concretemasonry is offline   Reply With Quote
Old 11-15-2011, 05:31 PM   #3
Framing Contractor
What does that mean? Foundation for what ...and are you talking about sticking 6x6's in the ground with no concrete?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-15-2011, 07:29 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
Wood has been used as footings and foundations before, what exactly are you trying to do?
Andy.
AndyGump is offline   Reply With Quote
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
Attaching Porch Post to Foundation Earnie Building & Construction 4 03-15-2010 09:38 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
Are ther alternative to Wooden Post on Deck Foundation herbolaryo Carpentry 2 05-27-2007 08:55 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
