Old 10-29-2009, 01:38 AM   #1
Independent old lady.
Default Foundation pier needs bank support.
Aloha,
Have a pier on a bank that is falling away I need to add support to.
Home is above ground with ¾ on rocky soil bank. The remaining 1/3rd (behind me taking photo) the bank was cut out and remainder foundation is cement slab bottom floor, open basement you might call it I guess.
This is not a water problem, water never in there, no cold in the tropics. I think the general ground is stable, the entire lot is on a bank and there was no damage in the last severe earthquake. (Ever seen your main ceiling beam moving 2' from center side to side like Godzilla was straddling the roof and slapping the house?)
This pier is directly in front of the only access to under the house and via the lower floor, I'm taking the photo lying on the floor from the doorway. House is 25+ old and the bank is sliding down from scrambling up it to access under the house. (It was me doing the scrambling J in the last 10 years or so.)
The photo makes the problem look worse than it was and there is no upper floor sag. It was only a corner hanging in the open before. I've begun to dig out to make to ground in front more level and stopped when the bank crumbled as it is now. The big rocks you see in front I dug out. The rock pile behind it is what I've been tossing up there for years (from the scrambling.) I've been planning to do something to support the bank for this pier for some time.
Now I'm going to I find I really don't know what would be a good way. What or how should I go about that exactly. I've got ideas and done some searching but not finding this sort of situation anywhere.
Could I dig a bit deeper and wider, lay down concrete block and fill w/cement and rebar? Should I build a form like steps sort of? Can I gather the largest rocks I can carry and put them in the bottom?
Is there a better way I can do it? Is there a resource book for this you know of that I just can't find? I've exhausted my local supply and not finding a dang thing.
Mahalo for your time.
redrover is offline   Reply With Quote
More On This Topic
I am Dr. T. K. Roy, speaking on behalf of Expert Village. Protecting our birds from predators, as I have already explained, there are different kinds. See, from the, from the rats, et cetera, which come from under the ground, you know. So what do they do... Read More »
Stone masonry structures are beautiful and very intricate. For large jobs, you must have a professional come in to do the work. However, you can perform smaller stone masonry jobs without the expense of hiring a professional stone mason, by learning the... Read More »
In our home renovation, we built a new entryway. What we did was this area that you see here connects with a long rock porch that goes around our house. This area, the full length of our house, was a cement porch. It was just bare cement and it went down... Read More »
Heating a Russian Tortoise
Heating a Russian Tortoise by Expert Village
Welcome to Regal Reptiles. Now that we have our reptile setup in his cement mixing bend, we are going to learn how to properly heat and take care of his temperature requirements. These Russian tortoises during the day they like to get very very warm... Read More »
Survivalists know how to construct shelters with whatever is available. In the desert, a shelter can mean the difference between life and death. Follow these tips to build a simple desert shelter from a poncho or blanket. Read More »
Foundation Repair Help rasilun Remodeling 1 10-16-2009 12:26 AM
Pier & beam foundation JustEnuf Carpentry 2 08-02-2009 09:58 PM
Ceiling joists support beam ptcamaro Building & Construction 3 06-17-2009 12:14 PM
Post N Pier Foundation question. deck99 Building & Construction 6 01-29-2009 07:02 PM
Pier foundation depth mike dunmire Building & Construction 0 10-09-2008 09:18 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
