Foundation Patch (superficial) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-23-2009, 07:05 PM   #1
Rewards Points: 260
Foundation patch (superficial)
I have a slab on grade foundation. The foundation doesn't have any cracks, but it isn't smooth in a few areas. It just has some indentions. I am going to paint the exposed foundation, so I would like to patch these areas. What is the best product for this?
bluefitness is offline   Reply With Quote
Old 01-23-2009, 08:20 PM   #2
Registered User
Termite's Avatar
A little hydraulic cement would work pretty well assuming the surface is clean. Hydraulic cement is very pasty and doesn't really have much of any aggregate, so it goes on like smooth peanut butter. You might want to rough up the surface just to be sure it has something to grab onto.
Old 01-25-2009, 09:37 PM   #3
Rewards Points: 260
Thanks. Do they sell this at the box stores? What about some type of cement patch or stucco patch?
Old 01-25-2009, 10:07 PM   #4
Registered User
Termite's Avatar
They sell it in small tubs.
Old 01-26-2009, 04:37 AM   #5
Remodeling Contractor
Or use a vinyl patching cement. This of the hydraulic cement are both available at box stores. Clean and rough up as suggested removing any loose material. Then apply a bonding agent to help the old and new cement stick.
Re-grading around foundation? robertr4836 Landscaping & Lawn Care 10 05-23-2009 05:34 PM
Foundation Patch: Hydrolic Cement?? roztom Building & Construction 38 09-07-2008 10:22 PM
Floor patch HomeDepot23 Flooring 2 07-24-2008 06:03 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
