Foundation Patch: Hydrolic Cement?? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-03-2008, 09:47 AM   #16
this is a sealant, NOT a structural part of pavement,,, to be certain the sealant can be supported, however, fill to appropriate depth w/CLEAN sand,,, read the previous suggestion,,, you do NOT want 3sided adhesion - ONLY both sides, NOT the bottom,,, there isn't any sealant designed for 3way.
yesitsconcrete is offline   Reply With Quote
Old 09-03-2008, 09:51 AM   #17
Rewards Points: 168
Since the dirt has washed out where the water drainage was, dies this sealer have enough density to sit in the crack/hole (not too big per photos) and cure?
tom
roztom is offline   Reply With Quote
Old 09-03-2008, 05:29 PM   #18
the sealant's NOT structural,,, if you use a non-sag & either fill the jnt as noted above OR install backer rod ( preferably closed cell ) of the appropriate dimension, won't make any difference to the sealant.
EDIT PREVIOUS POST,,, think i said sand,,, meant vermiculite,,, vermiculite's compressible, sand ain't !
yes.itsconcrete is offline   Reply With Quote
Old 09-03-2008, 05:41 PM   #19
BUILDER / REMODELING CONT
buletbob's Avatar
tom
My personal opion is to just rip it out and do it right. you will be at this for years and not gotten any where. BOB.
Old 09-03-2008, 06:23 PM   #20
Rewards Points: 168
Sorry I wasn't clear.
What should I rip out? All the concrete or all the patch that is crumbling?
tx,
Tom
Old 09-03-2008, 06:36 PM   #21
if i'm bob, depends IF you know how to place, finish, joint, & cure conc, rip it all out,,, if you don't, you can patch.
went back to look at the pics again,,, yikes ! ! !,,, you sure're bringin' propity values down, ain't yew ? ? ?
Old 09-04-2008, 05:10 PM   #22
buletbob's Avatar
tx,
Tom
I would rip the hole thing out. When you said the soil was washed out from under the concrete, made me think if this was the right thing to do.
is this your responsibility or the towns? being the garbage truck uses it.
Old 09-04-2008, 05:18 PM   #23
Rewards Points: 168
THe alley butts up against my slabs along side my foundation. Those slabs are just under 2 ft and are at a slight downward angle as in the photos.
I went to our local box store and found 2 different items:
1. Was a polyurethene tube concrete sealer/patch by Water-tite.
2. An Epoxy concrete sealer/patch for sealing concrete cracks which you mix by Rost-o-leum.
Both products said to use a Degreaser before applying. (recommendations?)
Does either one have an advantage or disadvantage? The epoxy costs less than the tube stuff.
The tube is about $3.50 for 10.5 oz.
The epoxy which you mix is about $17. and will do 14 lin feet.
THanks,
Tom
Old 09-06-2008, 01:55 AM   #24
In some of your pictures it looks like asphalt. You cant use uratheane on asphalt, it just wont hold. I own a waterproofing company and i'll tell you want i think should be done. First get rid of all the cement you put down, that wont work, it's got to be able to move and still hold. Second is go get a wire brush and duct tape it to a broom stick or something so you can stand up and brush the hell out of all the cracks. Third, blow all the areas with a leaf blower or broom it very good. Fourth, Any place where the crack is concrete to concrete use a TOOL GRADE uratheane not a pour grade. A pour grade will look like crap and it will be a mess plus you'll never get it sealed. They sell SIKA in uratheane tubes at homedepot. Just shoot it and tool it so its seald with something like the rounded end of a butter knife. Fifth, any where the crack is asphalt to concrete or asphalt to anything you must use an asphalt based product. the chemicals in asphalt eat urathane products. Try to find a mastic in tubes or an asphalt crack filler.
Hope this helped.
KC Brick Layer is offline   Reply With Quote
Old 09-06-2008, 08:40 AM   #25
Rewards Points: 168
Is the polyurethane in the tube the right stuff?
Also, would the epoxy work?
THanks,
Tom
Old 09-06-2008, 09:27 AM   #26
yes, the polyurethane in the tubes is the right stuff. No, epoxy will not work.
Old 09-06-2008, 10:17 AM   #27
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Epoxy is too Brittle and hard. It will not be flexible to be able to expand and contract.
- Build Well -
Old 09-06-2008, 01:44 PM   #28
concretemasonry's Avatar
Rewards Points: 2,578
Not an application for a patch job.
you can chase pennies and go through the same thing next year. If you enjoy that and do not have anything better to do, you can patch with good flexible materials, since you have an unstable material with poor support under it.
concretemasonry is offline   Reply With Quote
Old 09-06-2008, 07:33 PM   #29
buletbob's Avatar
Your 100% correct. ( BASE!!!) BOB
Old 09-06-2008, 10:46 PM   #30
Rewards Points: 1,088
Originally Posted by AtlanticWBConst. View Post
Yes, clean up the areas, remove loose material, and try Hydraulic cement (Water stop cement). It also has supperior abilities to adhere to other cement/concrete.
Would you use this water stop cement on cracked driveways also, or self leveling driveway caulk?
handy man88 is offline   Reply With Quote
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 06:32 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 01:53 PM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 02:49 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
