Old 10-01-2006, 08:08 PM   #1
card house builder
Foundation movement question
What does it mean if a foundation on a 200+ year old antique house is noted as inward or outward movement of foundation with some settling/sagging/deflection.
Is this to be expected with such an old house or is this most likely the tell-tale signs of major problems?
kelly001 is offline   Reply With Quote
Old 10-01-2006, 08:10 PM   #2
Is the movement recent or did it hapen a hundred years ago? NMI.
Tscarborough is offline   Reply With Quote
Old 10-01-2006, 10:13 PM   #3
card house builder
The seller's for a home we are considering had a consultant do a "home inspection" to assess their property. They have provided us with a copy of the results. The consultant noted those findings but did not ellaborate on paper.
We would obviously have a structural engineer look at the property if we put a bid and it is accepted however if this is a big problem, we would like to save ourselves the cost of hiring a structural engineer and home inspector. The overall condition for the structure/basement was assessed as marginal. (3 ratings were on the form appears fonctional, marginal and defective)
Old 10-01-2006, 10:22 PM   #4
Not to be rude, but there is nothing anyone on an internet BBS can contribute that would help you to assess this property in a significant way. You will need to have a structural engineer at a minimum, and probably an architect as well as consulting contractors to provide you with enough information to buy the home.
Old 10-02-2006, 12:25 AM   #5
Building inspector
inspects's Avatar
You should have a contractor look at the problem. An engineer is going to tell you "how" to fix it just like a "contractor" would.
A home inspector will tell you to have "three contractors" look at the problem and come up with a repair with quotes.
I would find three licensed contractors in the foundation business and have them all give you repair options with prices.
inspects is offline   Reply With Quote
Old 10-02-2006, 07:09 AM   #6
card house builder
Thanks for all the answers. Hopefully we can find a couple contractors to give us estimates in MA's hot market. Seems like they are impossible to get a hand on for such ellusive jobs.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 02:49 PM
foundation question for building a small cabin TNeat Building & Construction 3 08-01-2007 07:08 PM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 10:27 AM
Foundation question jerome8283 Building & Construction 3 01-18-2007 04:06 PM
