Old 01-29-2011, 10:38 AM   #1
Question
foundation leaks
Hi,
I am intending to finish my basement but want to repair tie rod leaks in the poured concrete foundation permanently before proceeding. These are roughly 5/8" holes that have been patched with cement on the outside and inside with the center being hollow (I've drilled out the inside on some). A few of these have leaked when we get heavy rain and when the snow melts in the spring.
I've done a lot of internet research and it appears using either hydraulic cement or polyurethane injection are the appropriate method to repair. I want the fix to be permanent and would like your input on which repair would be longer lasting. One site selling polyurethane injection materials mentioned that hydrophilic material wouldn't last as long as hydrophobic polyurethane as it breaks down with repeated wet dry cycles.
The holes are dry at this point so water isn't a concern.
I would appreciate any input regarding the best repair method.
Thanks.
fixonce is offline   Reply With Quote
Old 01-29-2011, 12:49 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
foundation leaks
They should have been repaired from the outside, in order to make them to not allow water intrusion.
Old 01-29-2011, 01:21 PM   #3
foundation leaks
Thanks for your quick response.
The original builder (house is 20 years old) did fix the holes inside and out with what I assume is hydraulic cement. Some of the holes are leaking and I'd like to fix them from the inside. I can drill out the holes and push hydraulic cement out with a dowel or inject polyurethane which should expand to the outside.
The part of the foundation involved is covered by concrete and a deck so it's not practical to dig and fix from outside.
Tags
basement, foundation, leak, leaks, rod
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 01:27 PM
rotten foundation form ties = crawlspace leaks? acordeon Building & Construction 5 09-26-2010 10:36 PM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 09:34 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 11:26 PM
Cracks in foundation....leaks....need some info. wackerjr Building & Construction 5 06-12-2006 02:15 PM
