#1 |
Foundation Issue - House Heaves in Cold Weather
We have a two story townhome built by a pond. No one can figure out why the walls separate from the ceilings and floors once it gets cold. Many windows have broken seal. The attic and crawl space have been examined by numerous professionals who just shrug their shoulders. The identical units on either side of us have no problems.
There has to be someone out there who has seen this situation and can help us with a solution. Once Spring arrives, everything comes back together and looks great. Each year the areas affected grow so that the entire perimeter of both floors shows spaces. Doors and windows are off kilter too. We've been told that every home settles. Well, this is not normal settling! Please help if you can. Thanks. |
#2 |
had 1 of those in nj - warren cty,,, same thing happened to mine every winter
finally i just look'd the other way in winter my theory was, since i was the corner t/h, the adjoining unit was on a different ' run ' of the foundation - never could find as-builts so its still theory.you're right - its NOT normal settling,,, see if your hoa will have some soil samples taken for a pe/lab to test,,, several spots of full depth excavation will also help,,, all these yrs & still can't look thru the ground
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Foundation or Load Bearing Wall Issue? | sheribaby | Building & Construction | 3 | 04-14-2010 06:07 PM |
| Water pooling next to house foundation pictures - help suggestions | Steelmesh | Building & Construction | 8 | 07-03-2009 11:05 AM |
| House Settling Issue (Hopefully) | dcd22 | Building & Construction | 20 | 08-29-2007 12:33 PM |
| cracked foundation on a new built house | wilddngy | Building & Construction | 2 | 05-06-2006 10:56 AM |
