Foundation Heave - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-29-2007, 10:48 PM   #1
Foundation heave
I have inherited a house with a heaved foundation. I've had a foundation repair company examine it and who recommended I install hydraulic jacks to lift the perimeter for a hefty sum. Is this my only option? Or will the heaving self-correct after the broken water pipe under the slab is fixed? Can the floors just be floated out in the interior? Does anyone have any insight into this issue?
greensmith is offline   Reply With Quote
Old 11-30-2007, 08:54 AM   #2
concretemasonry's Avatar
Rewards Points: 2,654
Slab on grade?
Not likely that any heave will correct itself enough for everything to come back to where it was.
concretemasonry is online now   Reply With Quote
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 01:49 PM
I need help Re: Poured Slab Foundation - Moved to Plumbing alextina Plumbing 6 04-19-2007 04:35 PM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 09:27 AM
Addition Foundation /Build. advice wannabuild Remodeling 3 12-15-2006 06:28 PM
