Foundation And Footing Cracks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-17-2011, 11:08 PM   #1
Foundation and footing cracks
I bought a 5 year old home and right after moving in noticed about and inch of water in the crawlspace. I had gutters installed (there were none before), removed vegetation next to the foundation and fixed the grade around the foundation. This is near Reno which has a relatively dry and cold winter climate. The night I noticed the water there was about a foot of snow on the roof and backyard that was melted suddenly when snow turned to rain. Since I made the corrections there has been no further problems with water in the crawlspace after storms. My only concern is that I have noticed several hairline cracks in the footings. I have pulled away most of the insulation along the foundation walls and noticed hairline cracks there too (but just a few). No cracks are larger than 1/16" wide. The photo shows one of the widest on the footing. Is it normal to have these kind of cracks?
willk53 is offline   Reply With Quote
Old 04-17-2011, 11:21 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Could the cracks be old and just exposed now that you torn off the insulation to reveal the area of the wall?
The cracks could be shrinkage cracks. The white stains appear to be efflorescence, which is a soluable salt that was probably from a previous slow water intrusion that carried salts from the concrete or the soil inside there it was deposited as the water evaporated.
Dick
concretemasonry is offline   Reply With Quote
Old 04-18-2011, 08:39 AM   #3
Rewards Points: 4,534
no, they're not normal but not rare, either,,, idoubt they're the major source of the wtr, tho.
Old 04-18-2011, 11:33 AM   #4
So should I be concerned? What should I do about them if anything? Sorry, but I've never lived in a house with a foundation before and seeing water down there was trumatic. I realize the cracks weren't the pathway for the water. Most of the water came under the footings and some I saw seeping above the footings (whereever those little metal brackets were). Like I said, I think I have stopped the water problem. My concern is just the cracks I saw. Looking under the insulation, the foundation walls only have a few hairline cracks (I can see 3 on the exterior wall). Otherwise it looks smooth and solid. There are more harline cracks in the footings and I'm not sure how to differentiate between shrinkage and more serious kinds of cracks. Thanks.
Old 04-22-2011, 02:42 PM   #5
Anyone else with answers?
Old 04-22-2011, 09:46 PM   #6
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 818
Hard to tell from one photo. In fact it's not possible to tell from photographs. I look at probably 4 or 5 slab and foundation problems a week. I will literally take 20 photos of one crack (different angles, different light) to make sure I document it properly for a report. I can't really be sure, but that looks like the hallmarks of a shrinkage crack. Shrinkage cracks occur within a certain time frame of the original pour, before the concrete is cured. Settlement cracks happen over time, and usually have some sort of dislocation (movement) associated with it. Regardless, you should try to seal the cracks, and monitor them to make sure they don't keep growing (width and length).
That's all I'm willing to say, because I don't want to tell you something one way or another without all the info and my eyes on it. If that's not enough to give some peace of mind, then if it were me and I didn't know, I'd call the town, explain the situation, and see if they had anyone that can stop by and look at it. If they don't, they might know someone who does. As a matter of fact, you or someone you know may know someone who does. It might be worth it to you for peace of mind to have someone check it out, and give you a walkthrough and an assessment on the entire structure while they're there. Just so you have a good idea of what's "behind the curtain" so to speak, and get good primer on how the structure is put together and what to expect.
Aggie67 is offline   Reply With Quote
The Following User Says Thank You to Aggie67 For This Useful Post:
willk53 (04-22-2011)
How does drain pipe around foundation footing end? pttcc Building & Construction 2 09-19-2010 09:46 AM
What is the on the base of the footing for standard circular steel form work for concrete be 12" wall and 36' foundation undation? william lum Building & Construction 1 06-24-2010 07:45 PM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 11:22 AM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 01:07 PM
Footing for Block ontop of existing Fieldstone foundation. Concerns w/ work done.. slowjo Building & Construction 6 04-26-2009 11:17 PM
