Foundation/driveway Gaps - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-25-2011, 12:09 PM   #1
foundation/driveway gaps
I have a 1941 home. Driveway redone 1983. House foundation clay brick. Driveway poured concrete. I was told its from settling, but the gap between the house and the driveway is now an 1/8-1/4". Husband used some black tar like crap (not male bashing) and it cracked where gap line runs around the house. What do I use to close that gap, water in basement last year, and I'm pretty sure thats the problem. Going to get estimates but would like your opinions so I can have a heads up when contractors come out. I keep reading about injectable randon seal and no clue what works and yet will still look fine being the contrast between gray concrete and the red/ faded red look of the clay brick.
LLJean is offline   Reply With Quote
Old 03-25-2011, 08:04 PM   #2
Rewards Points: 5,336
Sika makes an elastic, self leveling material perfect for this. It's applied with either a small or large caulking gun. If the crevice is deep, you can install backer rod to minimize the material.
You can find it in masonary supply stores and big box stores.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
LLJean (03-28-2011)
Old 03-26-2011, 06:13 AM   #3
Rewards Points: 4,738
if you're lucky, that's the source of the wtr but i'll bet that condition continues.
nevertheless, the ' gap ' calls for joint sealing w/elastomeric sealants,,, we prefer sika as it comes in colors ( not at any apron store, tho ) avail thru any pro const supply house,,, use backer rod to prevent installing it at an incorrect depth:width ratio,,, the w/site will give you proper directions,,, joint sidewall prep is critical to performance,,, btw, NO repair is permanent so anticipate replacement in ( 6 ? ) yrs,,, good luck !
The Following 2 Users Say Thank You to stadry For This Useful Post:
concretemasonry (03-26-2011), LLJean (03-28-2011)
Old 03-26-2011, 07:46 AM   #4
The local Home Depots here carry the Sika products in tan and gray.
Ron
sealing gaps in white cabinets? MrLinux Painting 2 10-25-2010 09:16 AM
cutting expansion gaps in underlayment boxy_brown Flooring 6 03-27-2010 04:54 PM
Purpose of gaps between sheets of plywood? diy888 Tiling, ceramics, marble 35 02-16-2009 11:01 AM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 01:31 PM
Gaps in tiled floor? peter1 Flooring 2 01-05-2008 08:23 AM
