Foundation Drains - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-31-2007, 11:15 AM   #1
Foundation drains
Foundation drain pipes extended into back yord and were covered by 2 feet of fill. Now with heavy rains water seeps under the foundation at the edge of house and into the basement seemingly under the 2x4 along basement floor. What should be done and what type of skills, Drainage, landscape, stucco, builder, waterproofing firm or what?
JOB B is offline   Reply With Quote
Old 12-31-2007, 11:32 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 608
Ayuh,......
If it wasn't a Problem before you had the drainage tile Covered,.......
I'd imagine that Daylighting them Again would probably Cure the Issue now......
Bondo is online now   Reply With Quote
Old 12-31-2007, 05:42 PM   #3
Rewards Points: 16
A little more explanation on how your drain tile is run would be helpful. Where does it end. Are the ends of it covered? Do you have a sump pump?
ponch37300 is offline   Reply With Quote
Old 01-02-2008, 11:30 AM   #4
What is daylighting..cleaning them out with a snake or what? Who does it?
Old 01-02-2008, 11:34 AM   #5
No sump pump. Black flexpipe going to back yard was covered with lots of fill after installation. Gutter pipes go into ground with no outlet. Not enough slope from house also.
Old 01-02-2008, 12:07 PM   #6
Bondo's Avatar
Rewards Points: 608
Ayuh,......
Shine the Light of Day on it,..... Dig it Up,.... Extend it so it can Drain......
I suppose you could do it Yourself, with a Shovel........
It Sounds like you added Too Much Fill........
Either have it Regraded, or Export some of it.......
Basic 101 of Gradeing is to have enough fall from the building to allow Drainage........
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 02:49 PM
I need help Re: Poured Slab Foundation - Moved to Plumbing alextina Plumbing 6 04-19-2007 05:35 PM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 10:27 AM
re-enforcing foundation - southern cal jhb Building & Construction 1 10-02-2006 01:15 AM
