Foundation Drain - How Much Water Comes Out - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 08:05 AM   #1
foundation drain - how much water comes out
I have a walkout basement with an exterior foundation drain tile. The grading around the house is pretty good (gets water away) and the downspouts are all routed at least 20 ft away from the house where no water will run back toward the house. How much water should be expected to come out of the drain tile in a normal everyday rain shower?
I have water trickling out during/after just a small rain....and pretty soon after the rain starts. I didn't expect to see any water coming out unless we had a huge rain where the ground is completely saturated and water table has risen. I especially didn't expect to see it trickling out just after a small rain starts.
88bomber is offline   Reply With Quote
Old 02-14-2013, 09:14 AM   #2
GBrackins's Avatar
Rewards Points: 2,108
not to sound smart, but if this is what you have coming out then this is what you can expect. Subsurface drainage can vary from one area to the next. Could be you have a higher ground water table so it does not take much rain before it reaches the level of your trench drain. And the amount of rain can be misleading, for example if you have a 20 square roof (square = 100 s.f.) then you have 2,000 s.f. surface area. In a 1-inch rain event your roof will shed about 1200 gallons of water, which is about 5 tons of water. This does not count rain falling onto the ground or other impervious surfaces.
just my humble thoughts ....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 02-14-2013, 09:31 AM   #3
Rewards Points: 13,458
Small amount of rain small amount of water coming out, HMM.
I'd be more concerened if there was no water coming out.
Old 02-14-2013, 10:20 AM   #4
I see. I just assumed that if water was being shed appropriately, I would see no water coming out under normal conditions.
One more thing (separate question really), the drain tile is only exposed on one side of the house, the other side was just buried (no outlet). I also seriously doubt there is any pitch from the buried side to the open side...not really possible. Is that common?
Old 02-14-2013, 10:39 AM   #5
GBrackins's Avatar
yes as water seeks it own level. If water runs into the drain tile on the other side of the house it will still flow (speed depends on volume) and reach the outlet.
same basic principle as water comes out of the faucet in your bathtub, yet the entire bathtub fills up, not just the area directly below the faucet.
It is not uncommon to have only one outlet going to "daylight" (running on the ground).
Gary
Old 02-14-2013, 12:38 PM   #6
concretemasonry's Avatar
Rewards Points: 2,594
bomber -
Do you water your grass?
When you water the grass, the soil (depends on the type) may hold/absorb water and it does not act like a reservoir to the point where any small rain can go to the drains and show up as an effluent. This covers a lot more area than just the roof of a house.
Water does not just go down, since it can flow laterally in soil and upward (capillary action).
Dick
concretemasonry is online now   Reply With Quote
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 12:47 AM
Gravel against foundation to stop water mnp13 Building & Construction 14 11-11-2011 02:22 PM
Drain tile on exterior basement cjm94 Building & Construction 6 10-04-2011 12:11 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
