Foundation Cutting/walkout Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-06-2011, 02:30 AM   #1
Question
foundation cutting/walkout basement
I have a full unfinished basement that has 1 window. I would like to make the basement a walkout but am uncertain if this is even possible.
I do not want to change the window into a door. I want to cut out a doorway from the foundation; is that possible? If so, what type of credentials should the person have to cut the concrete foundation?
kcks66102 is offline   Reply With Quote
Old 06-06-2011, 07:18 AM   #2
DIY staff
Rewards Points: 7,174
The concrete cutting is usually performed ,oddly enough,by a 'concrete cutter' look in the yellow pages.
A concrete contractor is the best choice of trades to call in to engineer and perform the work (they will know how to get the plans done and approved). They will address drainage and retaining walls--sidewalks or stairs..
If you wish to DIY this you will still need plans (drainage --header to hold up the house--grading--)
And the services of a concrete cutter.----Mike---
Old 06-06-2011, 09:38 AM   #3
Rewards Points: 4,538
we cut many of those over the years using a bolt-on-to-the-wall diamond saw (hydraulic, elec, or air ) & even using a demo saw fitted w/24" diamond blades. not sure we were ever aqsked for 'credentials' but we always had to submit copies of our insurances - even to hrh, genl contractor, when we enlarged the windows on trump's plaza hotel,,, any competent cutting contractor can do the work.
Tags
basement finishing , cut concrete , foundation concrete , walkout basement
Vapor barrier requirement for finished basement JTK Building & Construction 13 02-05-2011 05:30 PM
Basement window formed in foundation. ianc435 Remodeling 3 11-12-2010 09:41 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
Over insulate basement? braverichard Building & Construction 26 06-22-2010 09:26 PM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 01:21 PM
