Foundation, Building On Sand. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-27-2011, 08:45 PM   #1
foundation, building on sand.
what type of foundation is recomended for building on sand, in canada.
leng is offline   Reply With Quote
Old 05-27-2011, 11:21 PM   #2
Rewards Points: 1,092
I think the only person to answer that with any accuracy is a local engineer. Myself, I'd never touch it, not knowing if sand may shift, or how wide footers need to be for bearing, or ????. I'd be curious to know what you hear.
The Following User Says Thank You to jklingel For This Useful Post:
leng (05-28-2011)
Old 05-28-2011, 06:05 AM   #3
On our beach areas, the only method allowed is pilings.
The Following User Says Thank You to Just Bill For This Useful Post:
leng (05-28-2011)
Old 05-28-2011, 07:57 AM   #4
concretemasonry's Avatar
Rewards Points: 2,608
The many different types of sand. (particle size, particle shape and gradations of different size particles). Also the amount of fines (clay, silt,) can increase the strength and stability as long as there are not too many fines.
Dredge fills where sand and water are pumped in are used frequently for light to medium loaded foundations.
If it is for a strip footing and down 2 to 4', it should not be a problem with most sands since the surrounding sand provides reistance to movement and shifting. On the top foot or so, it can be a problem.
An engineeer/technician can make a quick test (especially if a hole is dug) to determine the approximate bearing strength.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
leng (05-28-2011)
Old 05-28-2011, 10:31 AM   #5
there is some top soil, because my lot was all bush when i bought it. you can't put a basement in this area because of the sand and watertable is high. i thought about pilings, but bedrock is too deep. maybe surface pad with a few pilings down below frost line, which should help from shifting. what do you think? i am just building a 30x34 cabin on it, but we plan on living there year round.
getting a building permit after construction is done ChrisJJ General DIY Discussions 22 08-15-2012 08:18 AM
how to light sand texture ceiling mtom01 Painting 4 03-13-2010 12:11 AM
Help with 1920's foundation hacksepe Building & Construction 3 10-10-2009 04:32 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 12:19 PM
