Foundation Anchor Bolts And Sill Plate Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 12:28 AM   #1
DIYer
Rewards Points: 93
Foundation anchor bolts and sill plate question
What would you guys do:
Try to frame a wall on the ground then tip it up, pray to your deity and place it on perfectly aligned anchor bolts
OR
Bolt the sill plate down then toe nail the studs to it
dwoloz is offline   Reply With Quote
Old 05-16-2011, 12:54 AM   #2
just a tool guy
mickey cassiba's Avatar
Done it both ways...I prefer to raise the whole wall and drop it on the anchors. Not that hard, if you layout and frame the wall against the anchors. YMMV
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
Old 05-16-2011, 02:18 AM   #3
Rewards Points: 1,016
Build the wall and tilt it up and place it over the bolts. If it is to big to handle, get more help when time to tilt it up or build it in a couple sections.
Old 05-16-2011, 08:52 AM   #4
Civil Engineer
Rewards Points: 4,854
The alignment trick is to build the wall first, raise in into position over the bolts, then tap the bottom plate to form an indentation where the bolts are. Then you drill through the bottom plate at exactly the right location, no guesswork. For 1/2 inch bolt I use a 5/8 drill bit and a large washer with two nuts. A bit of overkill, but you never need to worry about the plate getting loose that way. You do have to make sure there is enough stickup of the bolt to allow for two nuts and a washer though.
Old 05-16-2011, 03:29 PM   #5
Framing Contractor
Originally Posted by dwoloz View Post
OR
That's the way I always do it. You will have no problems doing it that way.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 05-16-2011, 10:27 PM   #6
If you have to use the oversized washers due to being in a seismic zone, be very accurate with the placement of the bolts in the concrete - there is not much room for error.
As other have said - build the wall, put it against the bolts, mark and drill. It's not hard to get the wall to drop down over the bolts. Your BFH can help for things like this.
Old 05-16-2011, 11:11 PM   #7
Registered User
Rewards Points: 526
Production framers would snap a caulk line at inside wall edge, straighten bolts for plumb with 2' jack-pipe, set the plate on the bolt tops lightly, aligning to line on concrete at each bolt, tap lightly on plate marking each bolt, flip and drill them, add double tops if used, lay them all out bundled, frame wall, add 1-3/4" wide blocks (2x4 ripped w. saw) in front of bolts if 2x6 wall so when raising, plate lines-up close to centered bolt. Wall up-right, lift wall at each bolt with hammer handle to engage bolt, removing block. Need two people if larger wall, no ladder work, way quicker... Start your end nails in the double-top for aligning wall with string inside edge later while on the slab. Do your joist/rafter layout while wall is down, no ladders but to tie the string and nail corners. Don't forget the sill sealer for thermal/capillary break, and possibly the termite shield.
Gary
Old 05-17-2011, 07:17 AM   #8
Rewards Points: 1,216
Place bolts in wet concrete, put pressure treated lower plate next to bolts, mark lines on both sides of bolts with a small square, mark spot on plate at bolt, drill out plate holes, install termite shield, put plate over bolts hammer down to shield, secure plate with washers and nuts.
Then raise wall and toenail to lower plate.
COLDIRON is offline   Reply With Quote
Sill plate and rim joist question bhasty Building & Construction 3 10-15-2009 02:07 PM
sill plate repair over block foundation MARLE Building & Construction 14 05-04-2009 08:03 PM
rotted sill plate, joist ends and stud bottoms oh my. slowjo Building & Construction 16 05-02-2009 09:43 PM
Sill Plate Question Colby Building & Construction 4 02-19-2009 01:16 AM
Replacing Sill plate Question Electromech31 General DIY Discussions 6 09-17-2008 09:08 AM
