Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 12:09 PM   #1
foundation
What is the maximum distance allowed between block pillars in the foundation of a residential dwelling?
kayhp7 is offline   Reply With Quote
Old 07-05-2010, 11:37 PM   #2
Concrete & Masonry
Rewards Points: 470
I could give you the answer to our local code requirements, but it would require about 6-7 pieces of information to be provided first, and would still probably be of no use to you.
Not exactly a black & white question or subsequent answer.
jomama45 is offline   Reply With Quote
Old 07-06-2010, 12:54 AM   #3
Contractor
Brickie's Avatar
Rewards Points: 79
Check with your local building department
Northwest Indiana Masonry
http://www.nwindianamasonry.com
Brickie is offline   Reply With Quote
Old 07-06-2010, 07:49 AM   #4
Old School
Willie T's Avatar
Yep, Building Dept. But do yourself a favor, and do NOT go down there without a set of plans they can use to determine your answer.
Willie T
Old 07-06-2010, 08:14 AM   #5
concretemasonry's Avatar
Rewards Points: 2,570
Normally "pillars" or pilasters are not needed with decent design. Much depends on the home footprint, the depth and the soil type and moisture content.
Dick
concretemasonry is offline   Reply With Quote
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 09:34 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 11:26 PM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 11:22 AM
mulch against foundation??? fabian Landscaping & Lawn Care 2 05-08-2009 10:38 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
