Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-29-2009, 10:12 AM   #1
Foundation
Ok lets start out this way. I live in Oklahoma county in Oklahoma. I am looking for any info on what I need to know on putting in a new home foundation. Around here all the homes seem to be put on slabs, but I am looking for the most cost effective, but still a good strong foundation.
Glenn Chambers is offline   Reply With Quote
Old 11-29-2009, 10:55 AM   #2
Civil Engineer
Rewards Points: 4,514
Are you looking for information so you can install the foundation yourself? If not, perhaps you should check with a few contractors in the are who install foundations.
Old 11-29-2009, 12:02 PM   #3
No I was planing on doing the work my self. I am from Michigan and used to building on basements. But out here in Oklahoma they do things different. I wood like to put in a basement, but I heard it's not the best way to go about it. But I wonder if I have to go slab, or if I can go with a footing and block to make a crawl space.
Old 11-29-2009, 03:41 PM   #4
Civil Engineer
Oklahoma is an area with moderate incidence of expansive soils. See http://geology.com/articles/expansive-soil.shtml for a general map of expansive soils. If you are building in an area with expansive soils, you must use specialized foundation techniques to minimize the potential for potentially damaging foundation problems.
Specific possible techniques include post tensioned slabs, pile foundations, and moisture controlled foundations. Some of these techniques are well beyond the capability of the average DIY to correctly and safely construct.
I suggest you get in contact with a local foundation company, or perhaps an engineering firm that specializes in foundations, and discuss alternatives with them. Unless you have considerable training, you are not going to be able to tell if you are in an area of swelling soils, you will need professional help to make that determination.
Foundation Repair Help rasilun Remodeling 1 10-15-2009 11:26 PM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 11:22 AM
Re-grading around foundation? robertr4836 Landscaping & Lawn Care 10 05-23-2009 06:34 PM
mulch against foundation??? fabian Landscaping & Lawn Care 2 05-08-2009 10:38 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
