Foundation For A 16x24 Structure - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-12-2011, 01:12 PM   #1
Marine Electrician (LO)
Foundation for a 16x24 structure
Hello everyone. My name is Alex. I am planning on building a 16'x24' structure on my property to replace a poorly built structure that existed there before. The basic idea is to have a building that is 1 story tall, and is heated and cooled for workouts and workout equipment.
I want this building to be very solid, and built to local and general code, with inspections and all. We've had trouble with neighbors in the past calling us out for even tiny changes in structures, so this is going to be done exactly by the book.
Now, I am an electrician and a carpenter, so the wiring will be a piece of cake, but my carpentry experience is mostly limited to building decks, and interior renovation. I've never built this kind of thing from scratch, so I need a good bit of help with it so it doesn't just collapse after I finish it. :P
I originally wanted to build on a wood foundation of sorts, but I'm thinking a concrete slab, wall, or cement block foundation would be better. The problem is, I don't know how to start, and I don't want the "norm" would be as far as foundations are concerned.
If anyone can help me out here I would really appreciate it. I just need some idea on how to start, especially the foundation, floor support, and roofing. I am limited in funds, so a good balance of quality and cost is important.
The whole thing will look a bit like this: http://www.llshedplans.com/images/gable280.gif
One door, and a couple of windows.
Thanks!
30Five is offline   Reply With Quote
Old 02-12-2011, 01:23 PM   #2
Experienced
Jackofall1's Avatar
Welcome 30five, to the best DIY'r site on the web.
Well I will be the first one to tell you this, go out and either buy plans, or have plans draw up by an designer/engineer. You should post your location as well this always helps with identifying the building codes for your area.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
30Five (02-13-2011)
Old 02-12-2011, 01:29 PM   #3
firehawkmph's Avatar
Rewards Points: 1,884
Alex,
That is a pretty straight-forward building. Like Mark said, first thing, go check with your local building department and see what they require for a foundation. I know what's required where I live, but it varies city to city around here. Once the foundation is in, that structure could be built in a weekend if you have a few buddies to help and at least one person who is a letig framing carpenter. Should be a fun project. Best to show your building department what you want to build to make sure they allow everything you want. A fellow just put up a 2 1/2 car garage in his backyard without trying to pull a permit. Turns out the homeowners association doesn't allow them. He had to tear it down. My buddy hauled away all the lumber.
Mike Hawkins
firehawkmph is online now   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
30Five (02-13-2011)
Old 02-12-2011, 02:01 PM   #4
Thanks for the suggestions guys. I live in Pascagoula MS, about 2 miles from the coast.
I will talk to the building inspectors and see what's required on Monday. As for the plans, that's probably the best thing to do, but I'm not sure where I could go to have a set of plans made.
Old 02-12-2011, 02:04 PM   #5
Experienced
Jackofall1's Avatar
There is a gentleman by the name of Andy Gump, at least that is his screen name, you could ask him for suggestions, as this is what he does for a living, he may be able to help you out with that.
http://www.diychatroom.com/members/andygump-90200/
Mark
The Following 2 Users Say Thank You to Jackofall1 For This Useful Post:
30Five (02-13-2011), AndyGump (02-12-2011)
Old 02-12-2011, 02:24 PM   #6
Mark
Excellent. I will contact him, and see if will help me out.
Old 02-12-2011, 03:48 PM   #7
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
I would love to put together a set of plans that would help you and fit your budget for this building and I wonder if the mods would let us share a lot of this on the forum.
This way others can see kind of what it takes to get a project like this going.
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
30Five (02-13-2011)
Old 02-12-2011, 04:06 PM   #8
AndyGump's Avatar
Rewards Points: 684
Well I just found out via the web that Pascagoula is on the 2006 International Building Code (IBC) and the International Residential code (IRC) for residential dwelling units of one and two family units.
The 2005 IEC, 2006 International Plumbing, Mechanical and Gas Codes.
There are loads of important info that you need to obtain even before picking someone to create plans like this form the local code book.
(c) All drawings, specifications and accompanying data shall bear the name and address of the designer. In the case of buildings or structures of Group `A', `E' and `I' occupancy, as determined by the building code adopted in this chapter, and all buildings or structures exceeding two stories in height and all structures exceeding 5,000 square feet in area, or of prefabricated metal building design, except one- and two-family dwellings, such designer shall be an architect or engineer, legally registered under the laws of this state regulating the practice of architecture or engineering and shall affix his official seal to such drawings, specifications, and accompanying data.
That was from section 14-44 (c) of the local codes.
Interesting stuff.
Andy.
30Five (02-13-2011)
Old 02-12-2011, 05:12 PM   #9
Civil Engineer
Rewards Points: 4,764
You are in prime hurricane country. I spent six months doing forensic investigations on failed structures in your area after hurricanes Katrina and Rita. Prior to those hurricanes, the building codes were a joke, and the joke was rarely enforced. Totally different situation today.
As noted, start by talking to the building inspector. They will steer you in the direction of required minimum standards, and they can certainly tell you what code book to purchase so you know the requirements. There may be local requirements beyond IRC, they will let you know.
In hurricane country, it is essential to pay attention to details such as use of hurricane clips to retain roof rafters, proper attachment of plywood sheathing to the framing, adequate ties between walls, protection of windows and doors from wind damage by flying debris, proper selection and attachment of roofing material, and adequate attachment of the framing to the foundation. All of these details are discussed in the IRC, however the local inspector may have specific requirements beyond the code.
If you purchase plans or hire an architect, be sure that the plans are specifically designed for the design wind load at your site.
Daniel Holzman is online now   Reply With Quote
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
30Five (02-13-2011), AndyGump (02-13-2011)
Old 02-13-2011, 10:50 AM   #10
Andy.
Thank you so much for replying to my thread. This forum rocks.
Interesting stuff.
Andy.
That is interesting. What exactly makes a building a "residential dwelling"? This building will be constructed similar to a house, but it won't be living/sleeping space for anyone. Is it the construction that determines it, or the purpose?
From what you quoted there, I don't think my structure would have to be designed by a licensed engineer or architect, right? I guess the best thing would be for me to just go talk to a building inspector and see what he/she says.
Thank you for the advice, I had not considered those aspects! I will definitely make sure to include your suggestions into the construction.
Old 02-13-2011, 11:06 AM   #11
Framing Contractor
That's exactly what you have to do.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
30Five (02-13-2011)
Old 02-13-2011, 12:00 PM   #12
AndyGump's Avatar
Rewards Points: 684
Ah, but it is "living" space because it will be used by people on a regular basis. Basically it is an accessory structure , an adjunct to your house so it is part of a single family dwelling.
Apparently it is not necessary for an Architect or engineer to draw up plans but engineering may be required if some part of the structure is outside the scope of "Conventional Light Framing" techniques.
Andy.
30Five (02-13-2011)
Old 02-13-2011, 12:29 PM   #13
Andy.
Okay then, I didn't realize that. Thank you. I will talk to the inspector on Monday if possible.
Old 02-13-2011, 05:25 PM   #14
Rewards Points: 212
Andy.
True, but it seems like a pretty simple structure. Ought to be able to put it together just using the span tables and such
A Squared is offline   Reply With Quote
Old 02-15-2011, 09:12 PM   #15
I didn't have a chance to talk with a BI today. Gonna get that done soon. I especially need a printout of the flood zone/evaluation info because the PDF online is horribly designed, and can barely open on my computer.
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 12:27 PM
prefab, min/no foundation structure??? shabba1985 Building & Construction 12 06-18-2010 04:53 AM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 08:34 AM
beach structure foundation archiect anwar Carpentry 3 11-01-2009 07:30 PM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
