Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 06:09 PM   #1
foundation
I have a 6 inch high foundation protruding 4 inches past the sill plate and wall that is on it. How do I cover this cement so that will not go moldy and will look good and is insulated.
dgrin is offline   Reply With Quote
Old 01-23-2012, 06:15 PM   #2
Rewards Points: 13,978
Where is it, house, garage, shed?
Any pictures?
Why do you think it's going to get moldy?
Old 01-23-2012, 06:40 PM   #3
Thanks for your response. It is a detached studio room at the back of my house. The prev. owner had glued plywood to the cement to cover it up and it had a black dusty mold on it. I removed the plywood and would like to water proof , insulate and put some kind of finish like sheet rock on it so it has a finished look. I need some advise as just what to do to this ledge.The room has a cement floor.
Thanks.
Don
Old 01-23-2012, 06:50 PM   #4
What's on the outside?
Sounds like a stem wall, two choices, box it in or build the wall out.
The likly reason it moulded up is it's not waterproofed on the outside, and that materail should never have been directly atached to concrete. Never put any wood except pressure treated wood in direct contact with concrete.
Paneling would wick up moisture.
Old 01-23-2012, 07:28 PM   #5
The out side cement foundation that is above ground is painted. How would I box it in? Vapour barrier, hard insulation , spray foam ?
Can I paint a water proof sealer on the outside.
Don
Will add a picture later today.
Foundation wall project and spread footings WillK Building & Construction 0 08-31-2011 12:46 PM
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 12:27 PM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 08:34 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
