Foundation For A 12X14 Shed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-30-2007, 09:00 PM   #1
Foundation for a 12X14 Shed
I'm planing to build a 12X14 Shed in my backyard, when it rains water takes a couple of days to drain out so I would like to stay away from treated wood as a foundation, then I checked out some sheds at home depot and they use 2X6 Galvanized steed joists for there sheds but they do not sell these joists. any ideas?? Thanks
emaizar is offline   Reply With Quote
Old 04-01-2007, 04:04 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You could build it on a foundation or layer of 8" cinder blocks with 4X6" pressure-treated beams over that. I would make all of the exterior either pressure-treated wood and plywood.
If you use a quality brand name of pressure treated wood, it should have a 50-year limited warranty. Make sure that you use p-t wood with the proper treatments level. (At least 1.0, I would think. That means one pound of chemical per cubic foot of wood.) Check with the a knowledgeable dealer.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 01:49 PM
Subpanel to Shed - Check my plan NateHanson Electrical 9 04-26-2007 09:56 PM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 09:27 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
Help Needed: Hurricane-proofing a Shed (Mr. Teetorbilt?) Badseed Building & Construction 3 08-01-2005 11:09 PM
