Found structural problem
If you have found it, why haven't you put in some jackstuds or kingstuds to fix it. Some things should just be left unsaid to the Interwebs, and should be fixed and people move on to other things.
BTW, it appears that it is not even load bearing, so does it really matter. Then again, who knows what other hidden gems are in that place. This is why I am going to keep this house that we have, because I know that know one screwed with it during the years, and it has pretty much been unchanged, minus the wall that we properly removed between the Kitchen and dining room.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
