Found Crack In Foundation - How Bad Is It? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-08-2014, 05:01 PM   #1
Rewards Points: 35
found crack in foundation - how bad is it?
While installing an egress window - the contractor found a crack in the foundation under the girder. I've attached a pic of the crack and another of the girder above it. How bad does it look? Is this something that I can fix with over the counter stuff? The contractor suggested just putting a 2x8 underneath it for add'l support - what do you think?
found crack in foundation - how bad is it?-crack-foundation.jpg   found crack in foundation - how bad is it?-girder-above-crack-foundation.jpg
cgott42 is offline   Reply With Quote
Old 09-08-2014, 05:28 PM   #2
MarginallyQualified
Rewards Points: 2,464
As Forrest would say: "Crack Happens"
In other news the sky is blue.
The Following User Says Thank You to TarheelTerp For This Useful Post:
gregzoll (09-09-2014)
Old 09-08-2014, 05:31 PM   #3
Rewards Points: 35
Does that mean that it's not bad, and to leave it alone?
Old 09-08-2014, 07:17 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 854
That one looks a bit more invasive to me.
Most foundation cracks are more aesthetic than structural. That one doesn't look to good to me given where it is and the crumbling nature of the crack.
Old 09-08-2014, 11:43 PM   #5
Rewards Points: 175
Don't forget to finish foaming in that window
Flooring Installer. Ecological Restoration Technician. Green Building Enthusiast. Obsessed with insulating and air sealing.
wewantutopia is offline   Reply With Quote
Old 09-09-2014, 12:32 PM   #6
Rewards Points: 179
are you sure the contractor didnt cause the crack getting that window in there?
windowguy is offline   Reply With Quote
Old 09-09-2014, 12:44 PM   #7
Rewards Points: 35
lol- I was wondering the same thing - I mentioned that to him, and he said that he noticed it before working and mentioned to me on the phone. I'm actually friends with him - so I trust him, plus since the crack seems to go up to the girder - I'm guessing that's where it started (layman's view).
Old 09-09-2014, 12:49 PM   #8
Rewards Points: 35
What do you think that I should do? approx. cost?
Old 09-09-2014, 03:08 PM   #9
Rewards Points: 3,344
Is that a poured concrete foundation or cmu's with parging???
Canarywood1 is online now   Reply With Quote
Old 09-09-2014, 04:07 PM   #10
Rewards Points: 35
I think it's poured concrete
Old 09-09-2014, 04:56 PM   #11
Not a time to "think" about what it is, you need to KNOW if it's poured or cmu's, if cmu's it could be the parging that's cracked then a simple fix, or it could be the cmu's and parging failing.
Old 09-09-2014, 05:05 PM   #12
Rewards Points: 35
Did a google / wikipedia search to find out what CMU's and "parging" is. IF I'm understanding correctly CMU's mean cinder blocks and parging is 1/4" - 1/2" inch of finish put on top
How can I tell what I have? (though perhaps you can tell from the first pic as the crack goes about 1/2")
Old 09-09-2014, 07:14 PM   #13
Can you see any of your foundation from outside of the house??, look for mortar joints of the blocks.
Old 09-09-2014, 07:26 PM   #14
Rewards Points: 35
yep I can see from the outside,don't see any joints
Old 09-09-2014, 07:38 PM   #15
Which means it's probably a poured concrete foundation, I've never seen a crack like the one in your pic, looks like it could be something serious, best thing would be to have a structural engineer have a look at it, can you see from outside if those cracks go all the way through??
The Following User Says Thank You to Canarywood1 For This Useful Post:
stadry (09-11-2014)
Need advice/opinions on leaky poured concrete foundation crack please (it's a novel) Wes8398 Concrete, Stone & Masonry 19 04-22-2013 10:53 AM
Foundation Crack...Who do i call? Flyerphann Concrete, Stone & Masonry 8 01-04-2013 11:21 PM
foundation joint-concrete floor crack repair? s002wjh Remodeling 3 01-12-2012 10:33 PM
Cinderblock Foundation Crack.. Pictures! Shawnzy Building & Construction 10 10-29-2011 12:10 PM
How to seal a leaking foundation crack from the home's exterior brokenhammer Building & Construction 5 01-02-2011 10:08 AM
