Forming For A Monolithic Footer Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 08:32 PM   #1
forming for a monolithic footer slab
What is the best way to form this after the footer is dug
i have trouble forming because the walls are weak and the stacks do not hold the form boards good?
vernonniners is offline   Reply With Quote
Old 08-26-2011, 01:57 AM   #2
Rewards Points: 1,092
longer and/or more frequent stakes, then tie-backs on the outside every 4'. worked for me.
Old 08-26-2011, 09:42 AM   #3
Too Old
I use 2x12 form boards with 2 stakes every 4' most of the ground around here is hard so 3' stakes work good, put 1 stake vertical and one at a 45 angle to give support from having the board blowout. I always spray a releasing agent on the boards before I pour, makes it easy to strip the forms.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Need Advice on Monolithic Slab TiredOld&Mean Building & Construction 0 06-12-2010 09:24 PM
insulating a slab w/o footer for greenhouse dc loud Building & Construction 2 04-17-2010 07:04 PM
Footer size for a monolithic patio that can support simple roof seth Building & Construction 2 05-19-2009 09:19 PM
Question on Monolithic slab - Pour all at once? seth Building & Construction 15 05-06-2009 03:36 PM
question on suitability of monolithic slab rtoni Building & Construction 5 03-31-2009 05:18 PM
