Forgot To Use Galvanized Nails... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-11-2009, 08:21 AM   #1
Forgot to use galvanized nails...
I just finished putting up about 30 feet of shadow box fencing (PT wood)and realized that the nails I got were not galvanized. Yes, I did know that I needed them and cannot believe that I didn't double check after having some problems finding the right nails for the framing nailer I was using.
Its only been up for a few weeks, but I can already see rust on the nail heads. I know there is a galvanizing spray for metel that may help, but will leave gray circles all over the fence.
I know the nails will not last as long as hot dipped galvanized nails - and for what its worth we will only be in the house for another 18 months or so - but anything I can do to prolong the life of the nails and reduce the apperance of rust would be greatly appreciated.
healeypd is offline   Reply With Quote
Old 05-11-2009, 08:45 AM   #2
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Epoxy
How about a dab of epoxy on the nail heads? Dries clear. Just the first thing that popped into my head. dorf Dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 05-11-2009, 08:46 AM   #3
the Musigician
DangerMouse's Avatar
wirebrush or steelwool the heads clean of rust and spray some clear laquer on them maybe? it won't last forever, but at least you won't have rust drips to deal with when you go to sell. you may need to do it the next year again, the clear will weather off rather quickly.
if concerned about lifespan, add the correct nails near the wrong ones.
DM
Old 05-11-2009, 03:37 PM   #4
Registered User
Termite's Avatar
Applying something to the exposed part of the nail head is like a bandaid on a cut artery. It won't do any good long term, or even short term for that matter. There will still be staining no matter what you do.
The nails will rust but will last quite a while before rusting through in most cases. My 3 year old fence still has the staples that hold the lumber tags hanging on, in ACQ lumber nonetheless!
Old 05-11-2009, 05:18 PM   #5
knewbie
curapa's Avatar
No, it would be a waste of time and money to do anything but remove the nails and re-nail with galvanized.
ParkerFenceandDeck.com
curapa is offline   Reply With Quote
Old 05-11-2009, 05:19 PM   #6
the Musigician
i thought the concern was for the chemicals in the PT wood corroding the nails away?
thus the coating?
DM
Old 05-11-2009, 06:51 PM   #7
He's not looking for a permanent fix
Just something that will last long enough so he can pass the problem on to the next home buyer
Old 05-12-2009, 08:52 AM   #8
knewbie
curapa's Avatar
thus the coating?
DM
The chemicals will cuase the nails to deteriorate pretty quickly in addition to the rust stains that will become very visible surrounding the nails and running down the fence boards. Take them out and re-nail, do it right.
Old 05-12-2009, 09:10 AM   #9
Wire brush nails, clean off rust stains then stain fence.
texas115115 is offline   Reply With Quote
firring out concrete wall for electric and insulation trouble Building & Construction 9 02-04-2009 11:40 AM
Type of nails for exterior trim bluefitness Building & Construction 2 12-07-2008 08:01 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
galvanized nails not for PT wood? darsunt Building & Construction 4 06-26-2008 08:20 PM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 10:54 AM
