Old 03-25-2008, 08:24 PM   #1
footings vs pylons
hello all : first post here
i am putting a 12' x 34' addition the back of a house, 1 story.
i was originally going to put sona tubes and insulate the floor.
cost of this support and insulation is about $800. ( no problem)
i am now thinking of about pouring a footing (outside parameter)
using 1" ridged styrofome on the outside of the footings. (underground)
footings will be 6" above ground level.
placeing a knee wall on top of the footings ( 2x6 pressure treated).
knee wall will be 2' high, and insulating this wall with styrofoam.
lightly insulating the new floor with fiberglass batts
the knee wall will be sheeted and covered with sideing.
do you think this would be a better idea than heavily insulating the new floor? ( stopping the some of the cold before it comes to the floor)
thanks in advance for your advice and sugestions !
reguards garry
smarbaga is offline   Reply With Quote
Old 03-26-2008, 10:53 PM   #2
conc repr & dec conc
Send a message via AIM to dec-conc-artisan Send a message via Yahoo to dec-conc-artisan
footings vs pylons
within WHAT parameters ? ? ?,,, what parameters are relevant ? ? ?,,, building code ? ? ?
dec-conc-artisan is offline   Reply With Quote
Having Addition built- question on footings joshjani Building & Construction 1 07-21-2007 07:03 AM
Footings? sandyman720 Building & Construction 1 05-30-2007 01:22 PM
Concrete shed footings in a marsh/wetland? tigerbalm2424 Building & Construction 11 03-27-2007 07:37 PM
Adding a room, footings for all walls, or just new exterior? mt232 Building & Construction 2 09-25-2006 07:55 PM
Footings jmontgom General Discussion 5 05-19-2006 01:32 PM
