Footings Required For A Header Replacing A Weight Bearing Wall In Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-25-2011, 05:01 PM   #1
footings required for a header replacing a weight bearing wall in basement
Are footings required for a header? I am replacing a wight bearing wall with a 11 foot header. The header will be made from LDL. The basement floor is concrete. One end of the header will will start from the cinderblock wall but will not be sitting on it. I have one contractor who says yes and another that says no.
Jimfuse is offline   Reply With Quote
Old 03-25-2011, 06:20 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
For a point load as in support for a post supporting a beam, I would say yes. What's LDL? Did you mean LVL?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 03-25-2011, 06:43 PM   #3
Concrete floors are not usually made to be capable of supporting weight. If the floor is overloaded, its likely to crack under the strain and then you will have all sorts of problems.
Footings need to be installed where the header posts are placed.
The contractor that says that footings are not required is, in my opinion giving questionable advice.
Old 03-26-2011, 06:58 AM   #4
Rewards Points: 2,240
I agree with "Wildie".
Minimum - 2 foot by 2 foot wide by 2 feet deep concrete, "Pad"/"footing" - under the existing, concrete floor. (Some re-bar would be nice).
rossfingal
rossfingal is offline   Reply With Quote
Old 03-26-2011, 06:34 PM   #5
Rewards Points: 16
It is impossible to say whether footings are needed without knowing what the wall currently supports.
Slabs on grade do have a load carrying capacity, but it is limited at the slab edge. I suspect, however, that if you're removing a portion of wall, that the post would be sitting on top of the existing stem wall and footing rather than the slab.
If it is sitting on the slab, it's a small matter for a structural engineer to give you the carrying capacity, but for only two footings, the engineering is likely worth more than the concrete to add a couple footings. Just make sure they're below the frost level!
As a structural engineer, my greater concern would be how the beam will be framed at the end to provide rotational stability. I have seen beams that were added like this that experienced uneven crushing at the columns and rotated until they were unstable.
druminman is offline   Reply With Quote
The Following 2 Users Say Thank You to druminman For This Useful Post:
concretemasonry (03-26-2011), rossfingal (03-27-2011)
Old 03-28-2011, 12:01 AM   #6
Too Old
Do you actually know how thick the slab is? I would do a footing.
havalife is offline   Reply With Quote
Old 03-28-2011, 08:58 AM   #7
concretemasonry's Avatar
Rewards Points: 2,650
On a typical basement, you never know thick the slab is and in many cases the soil under the slab could settle, creating a void and no soil support.
Either knock a hole in the slab to determine the thickness and soil type or just plan on footings for the columns. No sense in gambling.
Dick
concretemasonry is offline   Reply With Quote
Old 03-28-2011, 12:29 PM   #8
Concrete & Masonry
Rewards Points: 636
Dick
In my experience, I'd actually say "most" cases.
The footing is both easy & required IMO, assuming it's carrying any kind of load.
jomama45 is offline   Reply With Quote
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 08:39 AM
Load Bearing wall or not? Dennis6950 Remodeling 5 02-01-2011 08:34 PM
Is this wall bearing? adamgram Building & Construction 15 01-18-2011 09:32 PM
Bearing Wall Header? cbzdel Building & Construction 8 05-15-2010 10:23 PM
Non-load bearing window header in exterior wall timelyirony Building & Construction 3 12-08-2007 04:15 PM
