Old 06-13-2012, 09:54 PM   #16
Footings for a new house
Thanks for all the help and knowledge. The basement and footings were all dug to the same depth, which I think my earlier post made it sound that it was just the back. It got backfilled the next day after digging with the sand and a little clay mixture from the pasture behind the building site. What I am thinking, is just digging back down to the undisturbed clay and packing it with a packer. We were going to use that fill sand for the floor anyway. The house plan is full basement on the front and both sides, then about half way up with concrete on the back, and the rest framed in with 2x6 walls. The wood framing would have started a bit too low for comfort from the original depth dug.
Bajohnson is offline   Reply With Quote
Old 06-13-2012, 10:27 PM   #17
Average Joe/ex-Navy IC3
gregzoll's Avatar
Again, you dig down so that all footings are at the same level at the top. That means the higher section gets lowered, otherwise, you are going to have to adjust during the poor for the foot difference. As for being too low for the walls, as mentioned before, if the spec's called for a 9 foot wall, you now make it ten feet. Same if it was a eight foot wall, you make it now nine feet. Personally, a higher wall makes for better, when you go to finish the basement area.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
My house's previous owner - DIY horror stories Leah Frances General Discussion 118 03-14-2013 02:27 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 09:58 PM
