Old 05-30-2007, 12:39 PM   #1
Footings?
The construction office in my town says footings need to be 30". I dug the corners and from the top of my slab to the bottom of the concrete is 24". How do I go about adding to this to meet the code so I can build on this slab?
Thanks!
sandyman720 is offline   Reply With Quote
Old 05-30-2007, 01:22 PM   #2
concretemasonry's Avatar
Footings?
What are you building?
Dig to the prescribed level (proper solution) or add fill.
If you add fill, you may have to change the level of slad. If you add fill, you will have to sell the official on the idea of filling later to provide frost protection and keeping your wood far enough the finished grade.
Last edited by concretemasonry; 05-30-2007 at 01:31 PM. Reason: spelling, addition
concretemasonry is offline   Reply With Quote
Having Addition built- question on footings joshjani Building & Construction 1 07-21-2007 07:03 AM
Concrete shed footings in a marsh/wetland? tigerbalm2424 Building & Construction 11 03-27-2007 07:37 PM
refacing rubble concrete foundation footings Buck Building & Construction 2 10-25-2006 01:36 PM
Adding a room, footings for all walls, or just new exterior? mt232 Building & Construction 2 09-25-2006 07:55 PM
Footings jmontgom General Discussion 5 05-19-2006 01:32 PM
