Footings For 16" Sq Concrete Support Posts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-25-2010, 01:16 PM   #1
Question
Footings for 16" sq concrete support posts
We want to construct a 12x20 shed here in the Bahamas but cannot find code for footings for 16" sq support posts. Walls are T-111 and open above 4'. No electric, no water. Up north they should be 20x20x8. Without having to go below a freeze line at what depth should the footings be and what size square?
Any help is appreciated and thanks.
Leeside is offline   Reply With Quote
Old 01-25-2010, 02:13 PM   #2
concretemasonry's Avatar
Rewards Points: 2,608
Up north even where there is no frost, it is common to have the bottom of the footing of the 12" below grade and have it on firm soil. For an 8" thick footing many people have the slab 4" (1/2 of the thickness) beyond the edge of the column , wall or pier.
Since you have 16x16 columns you must have high loads or few columns. I would think your biggest problem is holding the shed down with good anchorage and keep it from flying into a house during one of your storms/hurricanes considering the height of the piers and shed.
concretemasonry is online now   Reply With Quote
Tags
bahamas , concrete , depth , footing
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 07:03 PM
concrete and fence posts rick32 General DIY Discussions 10 05-31-2009 03:56 AM
Support column footings Gregory Building & Construction 2 02-14-2007 09:05 PM
Framing 2 concrete posts in middle of basement yummy mummy Building & Construction 20 01-16-2007 02:14 PM
Installation of pergola posts HDelahay Landscaping & Lawn Care 13 10-11-2006 06:46 AM
