Footing Sizes For Deck In Md - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-12-2011, 08:01 PM   #1
footing sizes for deck in md
Hi all- I am looking to build a deck out back. The deck will be attached via a ledger board to double thick brick (using epoxy anchors - epcon a7).
Rough dimensions are 12x17 and I plan to have 5 posts on a beam that is approximately 11' off the ledger.
According to Montgomery County, MD's website, the requirement for footer diameter is 22" in diameter. If I calculate that out it is almost double what I need for load on each footer using this site -> http://www.ideasfordeckdesigns.com/c...calculator.php
Am I reading the requirement right? (http://permittingservices.montgomery...%20Package.pdf)
22" seems like a ridiculous requirement for a deck. I figure if I use 14" or 16" footers (soil bearing 2000 psf) I should have margin to spare and be safe.
Thoughts?
noname003 is offline   Reply With Quote
Old 09-12-2011, 08:28 PM   #2
Framing Contractor
Thoughts?
Call your building department and ask them. They will probably tell you that you can't ledger into brick.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 09-12-2011, 08:56 PM   #3
The house is made of all brick. I've seen references to ledger against brick. See the following
http://alexandriava.gov/uploadedFile...2010.09(1).pdf (page 12)
http://www.emcoblock.com/pdf/divisio...ck-masonry.pdf
Double brick doesn't qualify as brick vener does it?
Old 09-12-2011, 08:59 PM   #4
Say I made it freestanding, how does that impact footing size?
Old 09-12-2011, 09:26 PM   #5
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
according to the code, it seems like it doesn't impact diameter at all
Footings shall be minimum 20 inches square or 22 inches diameter (Figure 5). Bottom of footings
shall be a minimum of 24 inches below grade and shall bear on solid ground. For freestanding decks,
the footings close to the house must be installed as shown in Figure 6. Distances to the edges to the
footing and embedment of connectors must be in accordance with the manufacturer’s
recommendations
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 09-12-2011, 09:31 PM   #6
I'm not going to get a permit, but I am trying to build to code.
That aside, am I correct in saying that this requirement is extremely excessive?
Second, since my house is fully brick construction, does my ledger attachment method still pass muster?
Old 09-12-2011, 09:50 PM   #7
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
doesn't your code require you to pull a permit? this is like saying "I don't have a drivers license put am following all the rules of driving"
Old 09-13-2011, 05:23 PM   #8
Rewards Points: 5,336
It will effect footing depth. A footing within 5 feet(or so) of the foundation would require the depth to be down to the houses footings. Based on the fact that that soil was back fill and not undisturbed soil.
Ron
B. Franklin 1759
Old 09-13-2011, 11:16 PM   #9
Thanks for all the replies. I'm still trying to understand the following...
1. am I correct in saying that this requirement is extremely excessive?
2. since my house is fully brick construction, does my ledger attachment method (backer board where back side of wall is accessible, epoxy anchors where it is not) still pass muster?
Water supply line runs through footing site WillK Building & Construction 19 03-15-2011 02:39 PM
No footing with my 1950 poured concrete house? diy001 Building & Construction 2 01-14-2011 12:15 PM
Footing drains in crawlspace on top of footing jbitt Building & Construction 8 01-12-2010 02:50 PM
Sinking footing tubes Farmer Z Building & Construction 19 11-17-2009 09:50 AM
Wrong Footing Dimensions HELP jhernan35 Building & Construction 2 04-15-2007 03:22 PM
