Old 02-08-2011, 11:50 AM   #1
Footing for exterior stairs
Hi all,
I'm going to be relocating the exterior stairs of an existing deck, the new stairs will foot in my back yard. I'm looking for the accepted size and configuration/depth of a good footing for the stairs, which will be a standard 36" wide or thereabouts. Thanks in advance if someone can make suggestions.
Sampson
Sampson is offline   Reply With Quote
Old 02-08-2011, 11:56 AM   #2
Not so new
12penny's Avatar
.....try here, page 19
http://www.awc.org/publications/DCA/DCA6/DCA6-09.pdf
12penny is offline   Reply With Quote
Old 02-08-2011, 01:20 PM   #3
depends on where you live, your soil, and the size of the stairs
mrgins is offline   Reply With Quote
Old 02-08-2011, 05:19 PM   #4
concretemasonry's Avatar
The bigger and thicker, the better. It gets expensive to haul out and rebuild. Obviously you will not be consulting an engineer.
concretemasonry is offline   Reply With Quote
Deck Framing - Beams on top of footing (not enough space for post) Maatoy Building & Construction 18 06-02-2010 09:03 PM
Footing drains in crawlspace on top of footing jbitt Building & Construction 8 01-12-2010 02:50 PM
Sinking footing tubes Farmer Z Building & Construction 19 11-17-2009 09:50 AM
footing drain question chrisk Building & Construction 2 09-02-2007 08:21 PM
Wrong Footing Dimensions HELP jhernan35 Building & Construction 2 04-15-2007 03:22 PM
