Footing Drain Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-02-2007, 02:42 PM   #1
footing drain question
I'm doing a garage addition on a slightly sloping small city lot in Seattle. The garage floor slab will be at finish grade and the footing is 18" below the top of this slab. Must a footing drain be installed along the footing or can it be installed at or below the basement slab along the foundation wall? If it is installed at the footing I can not drain to daylight, but if it is installed along the wall just below the elevation of the slab i can drain to daylight.
Thanks for your help,
Chris
chrisk is offline   Reply With Quote
Old 09-02-2007, 07:18 PM   #2
Extreme DIY'r Adk's, NY
Rewards Points: 272
It sounds like if your drain exit is just below the floor, then with pitch it will be above the floor around the sides doing no good, no? I would either raise the slab slightly above grade in the front or forget the drain to light and just run extra perf pipe with common practices like in stone with silt barrier etc. Draining to light is great until some frogs make a mud nest up there or something and it backs up. really... not funny.
crecore is offline   Reply With Quote
Old 09-02-2007, 08:21 PM   #3
concretemasonry's Avatar
Rewards Points: 2,578
You can run your perforated pipe level. There is no need to slope it. You are trying to drain a general area, so the water will not build up with a level pipe.
The solid pipe for carrying the water away from the perforated pipe/french drain should be sloped.
concretemasonry is online now   Reply With Quote
French drain question Tom Fan Landscaping & Lawn Care 3 06-04-2007 07:16 PM
Dishwasher Drain Question kypper Plumbing 2 01-16-2007 12:39 AM
Shower drain question, diy'r Plumbing 6 11-14-2006 03:30 PM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
