Footing Depth For Deck Posts? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 08:35 AM   #1
Rewards Points: 117
Footing depth for deck posts?
Hi, I'm starting the kids' clubhouse which is essentially sitting on a 4-5ft high deck.
Area: 8x10'
Posts: 4x4 (thinking 9 total)
Looking at sonotubes and wanted to know:
1. Diameter if tube
2. Depth
There isn't a frost issue here and ill be anchoring metal bases for the posts to sit in.
Thanks folks.
Dornier is offline   Reply With Quote
Old 04-24-2013, 09:31 AM   #2
Roofmaster
Rewards Points: 2,210
Why are you going through all that for something that is probably temporary? The kids will use it for a couple of years, then you have all that money and structure there. Just build a base out of PT lumber with cross bracing.
Old 04-24-2013, 09:44 AM   #3
Rewards Points: 117
Well it'll be used for at least 6 more years. I have three kids over a range.
I already own the concrete.
It'll have a slide and curly crawling tube affixes as well as swings off a beam to one side.
I'd prefer to just make it as strong as possible.
footing for deck posts backwaterdogs Concrete, Stone & Masonry 4 11-25-2012 09:13 AM
Steel Posts for Screen Porch dobbsj Building & Construction 2 07-15-2009 05:47 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 02:55 PM
Installation of pergola posts HDelahay Landscaping & Lawn Care 13 10-11-2006 06:46 AM
Alaskan Slab Footing Depth new builder Building & Construction 3 06-15-2006 11:12 AM
