Footers - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-29-2011, 09:47 PM   #1
Footers
I am building a house and the guy who is doing my footers wants to form them and do the footers on-grade VS digging them. We are doing a stem wall. Is this a good idea?
stackman811 is offline   Reply With Quote
Old 07-29-2011, 09:54 PM   #2
Civil Engineer
Rewards Points: 4,514
I don't really understand what you are saying. Does your contractor propose to construct the "footer" from the ground up? If so, this would be highly unusual, and likely a very bad idea, but maybe I don't understand the plan. In general, footers for a house need to start below frost level, but they are also buried because the soil strength increases with depth for a variety of complex reasons. However, without an exact description of what is proposed, I really can't make a judgement.
One question though, do you have plans for the house, do you have a permit, and are you subject to building codes?
Old 07-29-2011, 10:00 PM   #3
The footers will be covered when the dirt is filled inside the stem wall. They will be built by 2x4s and 1/2" plywood, and filled. 2 courses of block on top of the footer for the stem wall and back filled and compacted after that.
New concrete slab - need footers? nyjets77 Building & Construction 3 04-26-2011 11:44 AM
New footers for temporary jack posts? revrsemigration Building & Construction 4 11-01-2010 02:28 PM
footers?? smith Building & Construction 10 02-04-2009 07:25 AM
rebar in footers ajoantmug Building & Construction 11 11-18-2008 10:11 AM
Deck footers not 100% level? ssgumby Building & Construction 1 05-11-2005 08:32 PM
