Footer Size For A Monolithic Patio That Can Support Simple Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-19-2009, 07:37 PM   #1
Footer size for a monolithic patio that can support simple roof
The cost of pouring a separate footer and slab is high, (Two pumps. trips etc) so I am looking at pouring a monolithic turn down slab with footer just enough to support a simple shed roof that can cover 20 X 20 patio. I am NOT building a two story, just a simple roof for a screened porch. I live in Greater Atlanta area
My questions are: 1) What should be the size of the footer of the monolithic slab? 2) Any disadvantages of a monolithic slab? (Crack etc). Thanks
seth is offline   Reply With Quote
Old 05-19-2009, 08:11 PM   #2
Old School
Willie T's Avatar
This is what we use here in Florida. If you need side support, same sized haunch around all three sides. That's a 45 degree slope. Three #5's.
Willie T
Old 05-19-2009, 09:19 PM   #3
DIY til I die!
We are pouring a 12x20 monolithic slab within the next week or so. I plan to remove the back wall of my garage and enclose the whole slab to end up with a 3-car, L-shaped garage. Since we plan to park a car on it if necessary, the slab will be 6" thick, fiberglass reinforced with rebar tying it to my existing slab. The footers will be 3' deep.
Zel1 is offline   Reply With Quote
simple deck roof crandan Roofing/Siding 4 07-24-2008 12:22 AM
how can I support my timber roof? cjwcarpentry Roofing/Siding 2 03-04-2007 01:52 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Patio Roof Renovation freddie Roofing/Siding 4 11-01-2006 09:01 PM
add roof to patio deck elfyperz Introductions 1 05-17-2006 05:37 PM
