#1 |
Footer Requirements
Does a 10x22 out/storage building (normal 2x4 construction) with a concrete floor require a footer?
#2 |
Household Handyman
Footer Requirements
IMO: This will depend on where you are located, the local building codes, etc. There are many quirks within jurisdictions. In my area, within the City Limits--Yes, you would be required to provide a footer for a concrete floor over nine (9) square feet. BUT, if you just get into the County, no footer until you get to one-hundred (100) square feet. BUT then again---you can buy a pre-built building, as large as they sell and will deliver under permitted load, which would require NO footer nor foundation at all within our City and/or County codes. Go figure. Check your local codes. David
| The Following User Says Thank You to Thurman For This Useful Post: | SlateRocky (08-15-2010) |
| Tags |
concrete floor, footer, out building ![]() |
| Display Modes | |
| How far from egress should I place a footer | LarryV | Building & Construction | 7 | 08-27-2009 09:49 PM |
| Footer size for a monolithic patio that can support simple roof | seth | Building & Construction | 2 | 05-19-2009 10:19 PM |
| Need advice on footer pier problem | paredown | Building & Construction | 3 | 03-20-2009 10:08 PM |
| Footer | deere2440 | Building & Construction | 7 | 03-01-2008 09:54 PM |
| Undercut footer | billinak | Building & Construction | 3 | 03-18-2005 07:34 PM |
