Foot Bridge - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-15-2008, 09:05 AM   #1
Foot Bridge
I want to build a foot bridge to croos a finger of my lake. It just needs to be wide enough to walk across. How far apart should I place the concrete piers and what size lumber should I use for the joists? The distance is 80'.
coresuper is offline   Reply With Quote
Old 11-15-2008, 09:27 AM   #2
Registered User
Termite's Avatar
If you use 2x10 #2 treated joists and space about three of them 16" apart, they'll span around 15'. 2x12's will go 19' or so. You'd need to devise something at each bearing point to provide lateral stability (roll resistance) that the decking alone will not provide. Blocking between the joists above the pier would be adequate.
Old 11-15-2008, 10:14 AM   #3
Thank you. I will install bridging to keep the joists from twisting at each pier and 1 centered between. Nice dog!! I also have a chocolate lab.
Repairing 2x4 foot drywall in ceiling LukeCT Remodeling 2 03-22-2008 12:55 AM
Cost per square foot -- very small addition rubeng Building & Construction 7 12-13-2007 01:41 AM
Over 8 Foot Wall - Method of Applying Sheathing... MoparAutoworks Building & Construction 14 08-20-2006 08:38 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
