Foil Backed Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-13-2010, 05:23 PM   #1
Rewards Points: 508
Foil backed drywall
Has anyone used foil backed drywall instead of poly sheeting? I heard of a builder doing this, and this idea, if it works, seems a lot more fun than poly sheeting.
benjamincall is offline   Reply With Quote
Old 05-13-2010, 07:16 PM   #2
Rewards Points: 582
It's used a lot over here.
http://www.insulationexpress.co.uk/V...pered-Edge.htm
stuart45 is offline   Reply With Quote
Old 05-13-2010, 08:09 PM   #3
Rewards Points: 508
So, this stuff serves as an internal vapor barrier?
Update:
Apparently the ASTM tests show this stuff has performance of under .1 perms. Now, where can I get some? Are the joints treated in any special way?
Old 05-13-2010, 09:35 PM   #4
Rewards Points: 508
Any ideas where I might find a lumber yard in the Northeast that stocks this stuff? Nationial Gypsum and US Gypsum both manufacture it, but I'm not sure who might have some in the yard.
Old 05-14-2010, 08:35 AM   #5
Rewards Points: 582
No, the boards are just fixed as normal, at least they are here.
Old 05-14-2010, 10:52 PM   #6
Totally screwed together
If you know who manufactures it, go to your local lumber yard and ask if they can order it. Heck, you would be surprised what Home Depot can order in at their contractor desk.
xxPaulCPxx is offline   Reply With Quote
Old 05-15-2010, 05:09 PM   #7
doesn't it get damaged in transit or during installation?
mrgins is offline   Reply With Quote
Foil Backed OSB DaveHembree Roofing/Siding 26 08-27-2013 02:46 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
