Foil Back Plasterboard - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-22-2008, 02:24 PM   #1
foil back plasterboard
if i am using kingspan insulation in the pary wall do i still need to use foil plasterboard? it is for a dormer...
yorkie is offline   Reply With Quote
Old 05-22-2008, 04:10 PM   #2
Registered User
Termite's Avatar
Not necessarily, although it won't hurt anything. Local ordinance might require it for some reason, so it warrants checking.
Party wall? Are you in a multifamily building? Sorry, just butting my nose in! The reason I ask is that if you're working in the firewall assembly, it needs to be put back with exactly the same materials that were in it when it was built. Otherwise the UL or GA listed fire assembly won't meet the listing it was designed with. Factors such as thickness of rock, taping method, insulation type, and nail or screw length/type all are very important details in a fire assembly. The addition of a dormer (if yours is new) can easily compromise the separation of two residences if the codes aren't strictly followed.
Foil Backed OSB DaveHembree Roofing/Siding 26 08-27-2013 01:46 PM
replacing metal back borch porch with shingles nurse47557 Roofing/Siding 1 05-21-2008 11:10 PM
sagging kitchen off back of house DanBress Building & Construction 12 03-03-2008 09:20 PM
Metal back box in a plasterboard wall Inquisitive Electrical 1 10-23-2007 01:24 PM
