Old 11-18-2011, 01:52 PM   #1
Foamboard sheathing
I have an external doorframe that I am closing up. I was wondering if I could use foamboard such as DOW SUPER TUFF R as the external sheathing. I do not plan on using osb or plywood in addition to this since the thickness would be more than the current sheathing.
From the studs to the outside: the layers would be stud, dow super tuff, tyvek, and hardboard siding.
from the inside, kraft faced insulation in the cavity and 1/2 inch gypsum.
TDKEY is offline   Reply With Quote
Old 11-19-2011, 12:48 AM   #2
Moderator
Foamboard sheathing
Sounds good, as there is probably enough shear on each side of the door to pass inspection when initially built. Air seal the drywall: http://www.buildingscience.com/docum...wall-approach/
Tape seal the Tyvek seams, add sill sealer or two rows of caulking under the bottom plate.
Gary
Clothes taking longer to dry?
Wall insulation techniques - 2x6 vs double 2x4 vs foamboard sheathing dwoloz Building & Construction 6 01-12-2011 10:58 PM
Replacing Rotting Sheathing Behind Chimney. fredhead Building & Construction 4 11-19-2010 09:57 AM
Can foamboard insulation be used in living areas, vaulted ceiling? Spud Building & Construction 14 10-13-2009 01:48 AM
New roof and Sheathing - Install new fascia before or after? hartkem Roofing 2 06-01-2009 01:12 PM
Sheathing with foamboard under siding billybarty Building & Construction 6 04-18-2008 01:46 PM
