Foam Sheathing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-21-2013, 09:25 PM   #1
Rewards Points: 396
Foam Sheathing
HI,
I noticed some 1/2" and 3/4" foam sheathing at the store. Does this replace standard OSB sheathing or is it installed over it?
detroittigerfan is offline   Reply With Quote
Old 08-21-2013, 09:43 PM   #2
Rewards Points: 13,732
It could be installed over it, Used to fill the gaps between the strapping when siding a block or concrete wall.
In my option it would be a very poor substute for real plywood or OSB sheathing.
It has 0 shear strength.
Old 08-22-2013, 12:39 AM   #3
Rewards Points: 396
Do you mean between strapping as in like furring strips attached to masonry and siding attached to the furring?
Old 08-22-2013, 07:50 AM   #4
Rewards Points: 396
Old 08-22-2013, 08:03 AM   #5
Yes. It adds a small amount of R factor and helps keep the siding from flexing between the strapping.
In some areas 3/4" foam is used for sheathing with Plywood or OSB only in the corners to help keep the wall from racking.
I've lived in one of those homes and any time a real gust of wind came through the whole house would crack and pop.
It was an on going issue with drywall screw pops and seams cracking.
woodworkbykirk (08-22-2013)
Old 08-22-2013, 08:09 AM   #6
Rewards Points: 396
Ya I would not trust just foam sheathing. Hey does vinly siding need strapping or draining plane? I was told no because it breathes naturally.
Old 08-22-2013, 08:34 AM   #7
Guess that depends on where you live.
All we ever do is add house wrap to the wall before adding the siding.
It allows the inside walls to breath and not form a double vapor barrier but keeps the outside condensation from getting to the sheathing.
mae-ling (08-22-2013)
Old 08-22-2013, 09:07 AM   #8
Rewards Points: 2,212
I am guessing the ones you are looking at are not structural, however there are some thicker ones (2") that I have seen that are.
There are also some that are used with diagonal bracing for the sheer strength.
mae-ling is offline   Reply With Quote
Old 08-22-2013, 11:23 AM   #9
Rewards Points: 396
In your opinion do you think adding ridid foam to the outside walls helps a lot with reducing heat gain and loss?
Old 08-22-2013, 01:40 PM   #10
GBrackins's Avatar
Rewards Points: 2,108
if you view a home with a thermal imaging camera you'll find that about 15% of the wall surface will transfer heat (studs, headers, etc.). adding rigid insulation board to the exterior side of the wall helps to eliminate heat transfer.
with that said you still have wall bracing requirements in your building code. In some area 1/2" wood structural panel sheathing (4' width) is installed at corners and at least every 25' along a wall. they will use 1/2" rigid insulation board in between the sheathing.
Add seismic and high wind requirements and you'll find a lot more use of wood structural panel.
the area I work in typically requires blocked wood structural panel sheathing on the exterior side of the wall to act as shear walls (due to being in a hurricane wind zone). all exterior walls are covered in sheathing.
I have had projects that required 1" rigid insulation applied to the exterior to comply with the 2009 International Energy Conservation Code requirements for my area. makes for fun with windows and doors.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-22-2013, 04:22 PM   #11
Rewards Points: 396
If your using 1" rigid insulation are you using window with longer jambs/frames?
Old 08-22-2013, 04:26 PM   #12
Windows and door can be custom ordered with jambs made to size, or for 2 X 4 or 2 X 6 studded walls.
Not a big deal to make your own extension jambs.
Old 08-22-2013, 04:35 PM   #13
Rewards Points: 396
right but if you add 1 or 2" of rigid foam that increases the wall depth, thus, not all of the window is on the rough sill unless you use replacement windows.
Old 08-22-2013, 07:56 PM   #14
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,212
build out hte rough opening with 5/4 stock or 2x stock and foam up to that so the window is fully supported..
woodworkbykirk is offline   Reply With Quote
Pairing Rigid foam insulation with existing wall cavity Izaura Insulation 8 03-30-2013 07:56 PM
R3 Rigid Foam for sheathing?? iteach4jeeps Insulation 21 12-03-2012 05:59 PM
Scissor trusses, Foam and FG zambo Insulation 2 11-15-2012 06:15 AM
Spray Foam into walls behind kitchen cabinets? MovedTooMuch Insulation 4 09-21-2011 09:33 AM
Replace Flange in basement with Foam? mattoxda Plumbing 1 10-10-2010 04:05 PM
