Foam Insulation Wall Cavity Soundproofing... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-03-2009, 03:06 PM   #1
Foam insulation wall cavity soundproofing...
To sound-proof between rooms I'm going to drill down between studs from the attic and put a foam insulation like "Great Stuff" down into each wall cavity. Does anyone have experience doing this?
I'm wondering how much should go down into a standard 16" wide cavity? They say to fill to 50%, but since I can't see down into the hole to see how much that is, I was hoping somebody has done this before... and I don't want to push the drywall away from the studs due to over-filling.
Any suggestions would be great!
CGehlhausen is offline   Reply With Quote
Old 09-03-2009, 04:56 PM   #2
WaldenL's Avatar
Rewards Points: 268
Great Stuff in a stud cavity? How many cans are you planning on buying?
WaldenL is offline   Reply With Quote
Old 09-03-2009, 05:26 PM   #3
Expensive, and if you get the red can(expanding foam), you could blow out the drywall. Not really a good idea.
Old 09-05-2009, 03:20 PM   #4
Rewards Points: 12
I doubt that this would be effective at soundproofing. For this purpose fiberglass is the usual choice. Rock wool or mineral fiber is used in most recording studios - you could cut channels in your drywall to squeeze it in between studs, then patch. If you want to improve sound isolation, you could hang an additional layer of drywall - isolate the two layers with a bead of acoustical adhesive (or at least use liquid nails), mud, tape and finish. Also be sure to seal _any_ openings between the two walls - at the base, in the outlet and switch boxes etc. This is often the biggest source of a sound leakage problem.
This company makes a number of acoustical products.
http://www.auralex.com/c_studio_cons...nstruction.asp
Good luck.
pianodude is offline   Reply With Quote
Tags
cavity , foam , insulation , soundproofing , wall
Installing Rigid Foam Insulation and Drywall raheel Drywall & Plaster 3 02-16-2009 06:07 AM
Foam Insulation in Basement - evicting the rats MacGuyveur Building & Construction 3 08-26-2008 10:37 AM
Best way to affix 2" foam board insulation to foundation wall BigJimmy Building & Construction 12 07-21-2008 11:50 AM
Noisy vibration of A/C lines in wall cavity tima2381 HVAC 2 07-17-2008 05:17 PM
no insulation behind wall boddah Remodeling 1 03-25-2008 03:11 PM
