Old 11-06-2008, 02:35 PM   #1
Foam Insulation question
Any thought son the slow rise foam insulation? I have an old townhouse with 5 inches of space between the walls and the brick.
I really do not want to remove all of the plaster.
Rickl is offline   Reply With Quote
Old 11-06-2008, 02:45 PM   #2
Theres more then one way.
iMisspell's Avatar
Last year i hired people to blow insulation into the walls (2x4) and also looked in to the foam... i was too scared about the foam installers making a mistake and blowing out the walls, too much of a head ack to deal with.
Something to keep in mind.
If you know someone who has the foam installed and thinks the installers did a good job, maybe get there number. Link anything, the people who are doing the job, create the out come.
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience -
- Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
Old 11-06-2008, 05:46 PM   #3
If the brick are exposed to weather there needs to be at least a 1" cavity between the brick and structure for moisture control.
rustyjames is offline   Reply With Quote
Old 11-06-2008, 06:06 PM   #4
Building A House
The foam insulation is great. But, I'd go with blown cellulose if you don't want to remove all of the plaster. The foam is too likely to over expand and blow out the wall.
Ezekiel is offline   Reply With Quote
Foam Insulation in Basement - evicting the rats MacGuyveur Building & Construction 3 08-26-2008 11:37 AM
pot lights and insulation question billie_t Remodeling 7 04-02-2008 09:07 PM
Venting foam board insulation mbscallen Building & Construction 5 02-15-2008 09:18 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
