Foam Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-13-2010, 07:01 AM   #1
foam insulation
We have a 6-year old crawl-space house, and our floor is very cold in the winter. Is it a good idea to spray foam insulation to warm things up?
mjo51 is offline   Reply With Quote
Old 12-13-2010, 07:20 AM   #2
Closed cell spray foam would be a GREAT way to fix that. Its a vapor barrier and a great insulator
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 12-13-2010, 07:38 AM   #3
Rewards Points: 558
The foam spray will expand and fill every single nook, cranny, crevice, hole, crack, and gap making a perfect continuous air-tight seal every time, regardless of complex framing and penetrations. This would be a great choice and the R value is un-compromised by external forces like temperature and wind.
epson is offline   Reply With Quote
Old 12-21-2010, 02:59 AM   #4
Rewards Points: 1,092
be sure to put a good vapor BARRIER, like 6 mil poly, Tuff Nuff, etc, on the ground, too. are the walls wood studs, or concrete block? if block, xps ("blue or pink board"), with taping the seams shut, is also an option, and cheaper than spray foam.
Old 12-21-2010, 01:21 PM   #5
Couldn't agree more with most, in a crawl space there is hardly a better option than 2+ inches of closed cell . It will do the trick for exactly what are you looking to accomplish.
jsesic is offline   Reply With Quote
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Is spray foam insulation that much better than fiberglass? HautingLu General DIY Discussions 18 09-21-2010 06:36 PM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 02:50 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
Venting foam board insulation mbscallen Building & Construction 5 02-15-2008 08:18 AM
