Foam Board Over Basement Walls? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 01:08 PM   #1
Rewards Points: 262
Foam board over basement walls?
Have a contact who is renovating a warehouse and they are pulling out 4'x8'x3" foam insulation panels. Eventually I plan to finish my basement, which is poured concrete, built in 2003, waterproofing-sprayed exterior, and drylok-ed interior.
What do you think about lining the walls with these panels before building it out? Glue them to the walls? Would they be very effective to hold more heat? My biggest concern is moisture down the road. Is it a valid concern? Just need help thinking through this one!!!
Thanks all
moneymgmt is offline   Reply With Quote
Old 01-25-2012, 07:48 AM   #2
Rewards Points: 262
So far the biggest problem I foresee is attaching my framing (or anything) to the concrete through a 3" surface. Although I suppose I could attach the walls to floor and ceiling joists and not attach horizontally to the foundation.
Good, bad, or otherwise?
Old 01-25-2012, 08:20 AM   #3
Rewards Points: 150
Yeah just fasten the walls to the joists and floor. No need to fasten to the wall. It seems using styro on the walls is the latest thing. I really like the idea of spray foaming but its quite expensive. I'll let others chime in regarding any pros and cons.
psilva8 is offline   Reply With Quote
Did I need to use Foam board in basement? dbeers16 Building & Construction 8 01-04-2011 01:01 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 02:43 PM
