Foam Board Adhesive - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-12-2008, 10:44 PM   #1
Foam Board Adhesive
Hi folks,
Want a recommendation on the best adhesive to fasten foam board (1/2 inch R2.5) to sheet metal duct work in a walk out basement. I live near Toronto On Canada so we have all 4 seasons.
I have read 300PL will do a good job but I thought one the surfaces must be porous for foam board and 300PL.
Thanks,
Art
atw58 is offline   Reply With Quote
Old 10-13-2008, 12:14 AM   #2
What can I find here?
Winchester's Avatar
Rewards Points: 150
PL300 adhesive has been suggested to me by an energy auditor.
Here's what I found on the product:
PL 300® Foam Board Adhesive
PL 300 provides dependable adhesion of foam to all types of surfaces, including wood, fiberglass panels, concrete, brick, metal and drywall. It is compatible with foam board insulation. It permanently joins the foam to the substrate without compromising the insulation value of the foam.
• Foam board compatible
• Bonds foam insulation to most common surfaces
• Works on foundation insulation
• Excellent for polystyrene and polyurethane molding and millwork
Best of luck
Winchester is offline   Reply With Quote
Old 10-13-2008, 03:19 PM   #3
Hi Winchester,
That is super. I will give it a try.
Thanks,
Art
House wrap over insulating foam board or under?? getn2old Building & Construction 7 07-28-2010 10:53 PM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 07:12 PM
Venting foam board insulation mbscallen Building & Construction 5 02-15-2008 08:18 AM
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 04:42 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
