Floorplan Balcony Support - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 03:39 PM   #1
I am drawing a floor plan for a house I want to build someday, and question I have is for second floor support. I have an open floor plan (kitchen/dinning/living room) and second floor has a balcony open to the living room below. (see attached pic) My question is if there is enough support for the balcony.
lmf_127 is offline   Reply With Quote
Old 04-04-2013, 03:49 PM   #2
DIY staff
Rewards Points: 7,174
Do you have a drawing that shows the location of the balcony?
Is that sketch the first floor?
I assume that sketch is a quick,not accurate ,rough draft----
Old 04-04-2013, 03:55 PM   #3
You can see the red lines inside the circle is where the balcony would be. All the red is a reference to the second floor, floorplan. This is accurate.
Old 04-04-2013, 04:17 PM   #4
DIY staff
How long is the span? From the left to the right of the stairs?
By the way----that door at the top of the starts is too close----must have a 3 foot langing at the top,before a door---
Old 04-04-2013, 04:22 PM   #5
19ft span. Thanks for the stair tip.
Old 04-04-2013, 04:56 PM   #6
DIY staff
That could be done with a laminated wood beam----
We have several members that have the knowledge to give you an idea of size--but yes,that can be done easily----
Old 04-04-2013, 05:13 PM   #7
GBrackins's Avatar
Rewards Points: 2,108
Mike, actually if their building code is based upon the International Residential Code then the stairs are allowed without a landing, as long as the door does not swing over the stairs. See Section 311.7.5 of the 2009 IRC
R311.7.5 Landings for stairways. There shall be a floor or landing at the top and bottom of each stairway. A flight of stairs shall not have a vertical rise larger than 12 feet (3658 mm) between floor levels or landings. The width of each landing shall not be less than the width of the stairway served. Every landing shall have a minimum dimension of 36 inches (914 mm) measured in the direction of travel.
Exception: A floor or landing is not required at the top of an interior flight of stairs, including stairs in an enclosed garage, provided a door does not swing over the stairs.
this is common in my area, but Imf would need to verify with his local building department.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following 2 Users Say Thank You to GBrackins For This Useful Post:
lmf_127 (04-04-2013), oh'mike (04-05-2013)
Old 04-04-2013, 06:30 PM   #8
So Mike as I was asking you are saying I do need to add a support beam? I wanted to know if I do need or not.
Old 04-04-2013, 07:58 PM   #9
Rewards Points: 252
Assuming the joists are going top to bottom and the beam left to right, what is it going to bear on? the left side is the kitchen and the right has a door in the way. With all the open space and angled walls it is going to be a difficult house to frame.
shazapple is offline   Reply With Quote
Old 04-04-2013, 09:49 PM   #10
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
I think you need to have the whole thing designed for you by someone who knows what they are doing.
Not just ask some throw-away question about one aspect of the project.
You may be in Calif. or you may be in Mississippi next to the coast or in Alaska with a 150 lb. snow load that will be affected in some way by the sizing of that beam.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
Can I build a third floor balcony? darkbrown Building & Construction 8 04-03-2013 04:53 PM
balcony supports Thanatos Building & Construction 0 03-06-2011 05:51 PM
Alterative ways to support main beam frizbplaya Building & Construction 8 01-29-2011 12:10 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 06:48 AM
