Flooring On Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-13-2010, 09:39 AM   #1
Question
Flooring on concrete
Does anyone know if you can put plywood on a concrete slab floor?
My idea was to put down a layer of 6 mil poly on top of the concrete followed by 5/8 t& g plywood. On the side of the plywood facing the concrete I was going to prime the plywood to help seal the ply. The reason for this is to eliminate moisture from getting to the vinyl flooring ontop.
Do you think it would work
Strach is offline   Reply With Quote
Old 07-13-2010, 11:53 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
If there is moisture, you will get mold growth on the concrete. It can't dry with the plastic on top.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 07-13-2010, 01:44 PM   #3
The slab is 5 years old and dry. I am more concerned with any excess moisture from concrete
Old 07-13-2010, 01:51 PM   #4
Rewards Points: 12
Have you moisture tested the concrete? It can look dry and still be giving off water vapor. Regardless, I think it's a bad idea to put wood on concrete. I have seen far more failures than successes.
Old 07-13-2010, 01:59 PM   #5
What if I put sleepers
Old 07-13-2010, 02:52 PM   #6
Registered User
Rewards Points: 4,914
http://www.buildingscience.com/docum...ms?full_view=1
Be safe, Gary
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
concrete flooring Jenn Pope Flooring 2 09-16-2009 07:02 PM
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 01:21 PM
Concrete alb preparation for Laminate (click together) flooring SJC Flooring 1 02-06-2008 03:16 PM
Laminate Flooring over Concrete kimmyb Flooring 1 01-28-2008 11:08 PM
