Flooring Cold From Furnace Intake - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 11:54 AM   #1
Post
Flooring cold from furnace intake
Hey... my cold air intake to my furnace runs across my house, between the floor joists. Even though they are insulated with Thermaduct (round insulation with barrier), the laminate flooring above gets cold. I live in Saskatoon, SK, Canada and it gets very cold here (we've had -40C temp's already this winter) and I'd like to fix this problem before I finish my basement. If I put rigid insulation between the floor and the intake ducting, would this work? Thanks for any suggestions.
Erin
flipper_79 is offline   Reply With Quote
Old 01-25-2009, 12:24 PM   #2
Rewards Points: 1,452
Yes, put in insulation between the duct and the floor above. Since there isn't much space for the insulation, choose the highest R-value you can; rigid foam is among the highest available. YOu'll also need insulation below the duct and above the ceiling when you finish the basement.
AllanJ is online now   Reply With Quote
Tags
furnace , insulation
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
Furnace installed. Intake from outside. DO i need it? Northland101 HVAC 5 11-28-2008 03:03 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 01:00 AM
