Floor And Wall By Door Is Soaked With Water - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-03-2013, 09:18 AM   #16
Rewards Points: 664
Originally Posted by joecaption View Post
It's not the stoop that's causing the real problum, it's the lack of flasing and seal under the door.
Thanks Joe. How do you think the water is getting in? I am wondering if the bad gutters are flowing over on to the awning and then somehow going down the siding along the wall. In that case the awning is the problem. See how black the gutters and awning are.
crescere is offline   Reply With Quote
Old 01-03-2013, 09:59 AM   #17
Rewards Points: 14,026
If you opened up that sheetrock to the ceiling you could narrow it down.
If it's stained at the top it cold be ice dams under the shingles, shingles cut to short so water getting in behind the fascia.
Old 01-03-2013, 10:14 AM   #18
Rewards Points: 664
I have been thinking of opening up the drywall. When I slipped my hand upwards it seems to get dryer the fartehr up I go, but there seems to be wet insulation.
